Contact Tracing
Reassure staff, students, and visitors as they return to the workplace.
Encourage social distancing and minimize risk
Aruba’s Wi-Fi and location services give you the built-in network intelligence to put safety first.
  • Density mapping so you can modify floorplans when traffic patterns become risky.
  • Contact tracing to minimize impact if the virus appears in the workplace.
  • All designed to keep your employees and customers safe.
Masked personnel working at an office with an open plan
Here’s how Aruba Contact Tracing works
Aruba access points next to mobile devices
Aruba APs listen
As users move through the workplace, Aruba APs listen for users, Wi-Fi devices, or Bluetooth tags.
Aruba Contact Tracing Live Map
Data is analyzed
Wi-Fi and Bluetooth Low Energy (BLE) location data is taken in and analyzed, then displayed in a cloud-based dashboard.
Aruba Contact Tracing screen
Someone is sick and contacts are traced
Once HR is notified that someone is sick, they can easily sort contacts by the total contact minutes with each person.
Aruba mobile usage heatmap
Locations are traced
Locations can be traced with dwell times at each AP pinpointing the exact locations for the sick person. Heat mapping can also help identify hot spots where people congregate, helping to optimize space usage and cleaning schedules.
What makes Aruba’s contact tracing solution different from all the rest?
Aruba’s network-based approach uses both proximity and location telemetry to perform contact and location tracing, and the advanced AI capabilities ensure pinpoint accuracy so you’re able to see which people intersected and the exact location of the interaction.
Components of the Aruba Contact Tracing solution
Aruba access point and tag next to a location dashboard
Aruba Access Points
Aruba APs enable a location-aware office and provide contact and location-based telemetry and indoor wayfinding using Wi-Fi, BLE, and data analytics.
Aruba Central
Central now has proximity tracing so you can run a simple query based on a username or MAC address to see who has come into contact with others.
Contact Tracing screen in Meridian
Aruba Meridian
Meridian works with Aruba 300/500 series APs and Aruba Tags to provide heat mapping and location analytics within a physical building or campus.
