Work from home with secure, always-on connectivity
The office-like experience in the comfort and safety of an employee’s home.
The toughest challenges IT teams face with a remote workforce
- Delivering the in-office experience at home is difficult.
- Applying consistent security controls can be tricky.
- Consumer-grade access points make help desk calls more difficult to resolve.
- New solutions rarely work right out of the box.
The Aruba work from home solution in 3 easy steps
Connect with confidence
IT ships an Aruba access point to the employee’s home; the employee plugs it in, downloads a configuration from the cloud, and they’re ready to go.
Secure the network
Centrally managed access credentials and Zero Trust Security that maps directly to corporate policies.
Managed from the cloud
Visibility, control, and AIOps assisted troubleshooting from anywhere.
Secure remote connectivity that IT can trust
The recent pandemic has highlighted the need for flexible and secure connectivity for employees working from home. At ATM Digital, we talked about solutions to keep employees productive and safe.
Establishing calm in the face of chaos
Components of Aruba’s remote work solutions
Remote Access Points
Aruba access points are automatically configured, so employees just plug them into any existing Internet connection and they’re ready to go.
Aruba ClearPass
ClearPass looks at each connection, and uses device and user context to simplify the authentication process, while allowing for certificates instead of passwords, rules based on the devices being used, and even the user’s location.
Aruba Central
By extending an enterprise Aruba network into the home, Aruba Central or Aruba AirWave allow IT admins to look at and monitor Aruba APs for an improved help desk experience.
Aruba VIA
When dedicated access points are not an option, Aruba VIA is easy to roll out, and is a cost-effective solution for your workforce—whether connecting on private or public networks.
Aruba ESP
Extend the secure, in-office experience to your remote workers with Aruba ESP — you gain AIOps insights, proactive troubleshooting, and the scale of the cloud.
Calculate your cost savings
By reducing initial deployment overhead, as well as ongoing support and user downtime, Aruba Remote Access Points deliver a compelling ROI. To get an idea of your potential savings, adjust the calculator to your current or expected number of remote users.
By reducing IT overhead and lost user productivity, you could save:
